I know That the Windsor crank has an 8 bolt pattern and the Romeo has a 6 bolt pattern but is there any other difference. I have a Windsor block but my stroker kit came with a crank for a Romeo block. I know I’m going to have to got a new flywheel
but is the crank pulley any different? On my old motor (Windsor) the crank pulley had a indent and the crank had a protruding groove so they would slip into each other and not slip but on the new crank there is a inward groove. So my question is are the crank pulleys any different with these two cranks. These cranks are interchangeable right??
Thanks,
John
but is the crank pulley any different? On my old motor (Windsor) the crank pulley had a indent and the crank had a protruding groove so they would slip into each other and not slip but on the new crank there is a inward groove. So my question is are the crank pulleys any different with these two cranks. These cranks are interchangeable right?? Thanks,
John
