I realize a distributor needs a certain type of gear so it won't be damaged by a steel roller cam. My question is, can a TFI style distributor be used with an older flat tappet style cam without causing any issues? Thanks.
I called comp cams once with this question, and they said you can use the steel type distributor gears on flat tappet cams but you cannot use a cast iron gear with a steel (roller) cam. But I would double check with them on that.
