Differential Dampner?
  • Thread starter Thread starter jabGT
  • Start date Start date Mar 24, 2004
J
jabGT
59
Michigan
Mar 24, 2004
  • Mar 24, 2004
I recently noticed the u-shaped dampner under the differential housing was snapped in half on my 95 GT. A new one cost $150. Does anyone know the importance of this, or if welding it would be sufficient?
fordman54935
301
Wisconsin
Mar 24, 2004
  • Mar 24, 2004
I would think that the piece could be welded back together. I know alot of people just take these things off to save weight. $150 for a new one is pretty absurd, and you could also call around the the local salvage yards to see if they have one.
G
gt90stang
568
  • Mar 24, 2004
I think it isn't metal, it feels like it is a composite material that is good at dampening vibrations. Get one from a junk yard or try to glue and stich it together with epoxy glue. Probably best to get a used one.
Don
Smeckel
751
Meriden, CT
Mar 24, 2004
  • Mar 24, 2004
Haven't had it on my car for the 2-1/2 years I've owned it and never had any issues. Was prolly off before that too.
ninety15.0
1,336
  • Mar 24, 2004
I think that what u are refering to is more comonly known as the dog bone. Im not exactly sure this is what ur talking about but pretty close. It's purpose from the factory is to remove harmonic vibrations caused by the stock rear-end and DS. You can just chuck it, i think a lot of people just rip it off anyways to save wieght. You really dont need it if you have a nice set of aftermarket gears and alum DS that are better balanced. Good luck hope this helps
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Mar 24, 2004
  • Mar 24, 2004
If you have stock ratio gears in your stang you may want to keep the dog bone on there. If you have aftermarket ratio gears in your car throw that heavy junk of metal in the garbage and get rid of some useless weight. It serves absolutley no purpose when a numerically higher gear is used.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical need help with a part number
  • alutwon
  • Jan 27, 2026
Fox 5.0 Mustang Tech Jan 27, 2026
alutwon
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
