Differential question.
  • Thread starter Thread starter 69Rcode_Mach1
  • Start date Start date May 2, 2004
69Rcode_Mach1
1,473
Salt Lake City, Utah
May 2, 2004
  • May 2, 2004
How do you identify your cars differential to see if its a ford 9 inch or not??
F
Fomocohipo
128
  • May 2, 2004
The 8 is oval shaped and the 9 is more round.
http://www.mustangsplus.com/tech/axles/index.htm
PoliceInterceptor
Keeper Of Automotive Oddities
2,161
Live in GA, But could be any where really.
May 2, 2004
  • May 2, 2004
Here is another one.
Note that the ends of the axel are not a 100% fool proof way to identify 31 spline axels.
http://www.kevinstang.com/Ninecase.htm
69Rcode_Mach1
1,473
May 3, 2004
  • May 3, 2004
Hey guys thanks alot youve been a big help i have the 9 inch.
Max Power
1,774
St Paul
May 4, 2004
  • May 4, 2004
Also, the bottom two bolts on the carrier for the 8 inch can be accessed striaght on with a socket, but the 9 inch ytou need to use a wrench, cause the carrier (pinion) sits lower.
chepsk8
2,203
Easton, PA
May 4, 2004
  • May 4, 2004
Does your rear still have the tag on it? If so, it will give you the gears, and posi or not.
If your "R" is a Drag-Pak, does it still have the "N" case? (only 3.91, 4.10, or 4.30 gears)
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
C
Fox 1993 LX 2.3 Wiring
  • Coyoteswap93
  • Jul 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2026
AeroCoupe
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
D
Resolved Help Identifying Sensor Part Under the Hood on 3.8L V6 1994 Mustang
  • DPP
  • May 27, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 27, 2025
DPP
D
