Digital Dash - Finally Got It To Work
toyman
1,944
54
79
Vernon BC
I bought this dash about 4 years ago but never got around to installing it. Tried late last year but ran into a number of issues that couldn't be resolved at the time. The big issue was that the system shut down the auto transmission control function in the EMS. As Nordskog closed their doors a few years ago there was no tech support to turn to which didn't help the situation. Turns out that the cluster was designed to work with a stock ECU and I'm using an AEM-EMS. However, with the help from an owner of a auto stereo shop and a couple of judiciously placed diodes in the wiring circuit we were able to get everything up and running. Here are a couple of pics.
It also has a number of features. The temp and oil pressure and volts are true readings and the speedo can be calibrated. It also stores high speed, 1/4 mile ET's and 0-60 times.
I may have to take the temp reading statement back. The new dash gauge reads about 6* higher than what I see monitoring the ECT sensor. Then as I think about it the ECT sensor reads the coolant temp just after the coolant has been through the rad and the dash sender in the stock location is when the coolant leaves the block. Does that make sense?
Looks sweet! I remember a good friend of mine had one in his Fox for years. It would draw a lot of attention at car shows because he'd leave it on. It's weird how many years I saw them in the Mustang mags and hardly seen any of them out in the world.
It's too bad these aren't available anymore, I'd consider installing one.
