  • Mustang Sound & Shine All
Dimming is bad...right?
  • Thread starter Thread starter AmBo
  • Start date Start date Mar 2, 2004
AmBo
1,027
New Jersey
Mar 2, 2004
  • Mar 2, 2004
[*UPDATE*] Dimming is bad...right?
Hey all! Just installed a 12" Kicker CompVR and an 800watt Kenwood amp. When i crank up the bass, my lights are dimming. AHHH!
Do I need a capacitor? Will this help? I'm running 4 guage wire so it's deff getting it's power worth.
I would like to NOT blow an alternator. PLEASE HELP!
R
Reider
Banned
Mar 2, 2004
  • Mar 2, 2004
Yes dimming is bad.
Capacitors are not usually the best way to go as they are only "Bandaids" for electrical problems.
You might want to upgrade the "Big 3" - Alternater, Battery, and the wires between them. Instead of buying a capacitor, save up for a bigger alternator + wiring, and a battery if need be. If you are only running that amplifier then you probably do not have a huge problem yet.
Do you know how big your battery is and how many amps your alternator is?
AmBo
1,027
New Jersey
Mar 2, 2004
  • Mar 2, 2004
I have no idea. It's a 00 vert. stock everything aside from system and catback exhaust.
all my buds say capacitor should fix it. It's only 800 watts of power.
93GreenLX
776
Southern Maryland
Mar 2, 2004
  • Mar 2, 2004
Yeah upgrade the alternator and use a 4 gauge power wire...very simple and well worth the money..I just installed a 200amp
R
Reider
Banned
Mar 2, 2004
  • Mar 2, 2004
Just what 93GreenLX said
Why put a bandaid on a deep cut when you can stitch it up and fix the problem?
R
Red2000GT
2,450
Regina,Sask.Canada
Mar 3, 2004
  • Mar 3, 2004
Reider said:
Yes dimming is bad.
I don't want to start a flame war but I disagree with you. A stiffening cap is not a band-aid fix. Many many competition vehicles use only one battery and a decent alternator for power sources. Wire guage is very important as always. A stock 2000 stang has a 120 amp alternator,large enough to run the car and that 1 amp. I wouldn't hesitate to install the cap,but double check the ground connections for the amp itself AND the factory battery ground.
There are 2 things to remember when putting a larger battery and alt---
1)an alt is much like an engine-you trade low rpm power for high rpm power,so the bigger unit will have to be spun higher to get the additional current. At typical 1500-2000 rpm around town engine speeds the bigger one will put out less than the smaller one.
2)A bigger battery creates a bigger strain on the electrical system. You could have a 1000 cranking amp battery and it wouldn't help the dimming the least little bit. It doesn't "release" the current fast enough for musical purposes.
A cap is cheaper and an easier install than a new alt. But double check and upgrade as neccessary all the grounds in the car.
R
Red2000GT
2,450
Regina,Sask.Canada
Mar 3, 2004
  • Mar 3, 2004
Sorry-I just wanted to add that what Reider suggested is not wrong in any way,upgrading the battery and alt is a good idea,but not NECCESSARY. The cap will work just as well,safely,for less hassle and less money.
93GreenLX
776
Southern Maryland
Mar 3, 2004
  • Mar 3, 2004
Regardless of everything I think everyone can agree that upgrading the big 3 is a must. I also agree with Red2000GT a cap WILL more than likely solve your problems. I have a friend with 3 amps, a 600watt and 2 800watt and he has the stock battery and alternator. He has 2 1.0 farad caps and they solved his dimming problems. I on the other hand have a little more than that, but 2 1.0 farad caps solved my problem too. Just to be on the safe side I have the 2 caps, an Optima battery and a 200amp alternator.
AmBo
1,027
New Jersey
Mar 3, 2004
  • Mar 3, 2004
So if I look towards a cap, what brand should I be looking at? Any suggestions? I'm only running a Kenwood 800watt.
93GreenLX
776
Southern Maryland
Mar 3, 2004
#10
  • Mar 3, 2004
  • #10
Just go to any reputable audio shop and tell them what you need...honestly I'm not even sure what kind I have
AmBo
1,027
New Jersey
Mar 3, 2004
#11
  • Mar 3, 2004
  • #11
oh you didnt install urself? DOH! I like to save $ and do it all my own.
Anyone else have brand names?
93GreenLX
776
Southern Maryland
Mar 3, 2004
#12
  • Mar 3, 2004
  • #12
Never said you had to have them install I said just go to any reputable audio shop and tell them what you need. I never said have them install it. Any reputable audio shop will carry good quality caps. What I meant by my statement was not to go to walmart or autozone or pepboys or anything to buy it and you'll have no worries about it being a quality cap
BBrinks
519
Woodridge, IL
Mar 3, 2004
#13
  • Mar 3, 2004
  • #13
I'd also recommend upgrading the 'Magic 3' wires:
+ to alt.
- to ground
engine block to chassis
The stock amp should handle that amp fine, but if you still have dimming problems, then I'd check into a cap/higher amp. alternator.
R
Red2000GT
2,450
Regina,Sask.Canada
Mar 3, 2004
#14
  • Mar 3, 2004
  • #14
We sell Rockford and Stinger where I work. Both are great but any recognizable car audio name should have one and will work. There's actually only 3 places in the entire world that make caps so you really only have 3 choices btw
AmBo
1,027
New Jersey
Mar 4, 2004
#15
  • Mar 4, 2004
  • #15
hey red, wanna get me a good deal on a cap?
AmBo
1,027
New Jersey
Mar 5, 2004
#16
  • Mar 5, 2004
  • #16
*UPDATE*
I changed the settings on my amp to not drain power, but I'm getting MORE bass! Does this make sense?
I turned on my LPF and set it to 0 I think and jacked my gain to about 1/4. Then I control the amount of bass from my HU. When it hits hard, the lights don't dim, but it is louder. I think this is good.
Does this make sense? Harder bass, no dim?
93GreenLX
776
Southern Maryland
Mar 5, 2004
#17
  • Mar 5, 2004
  • #17
Well if your subs aren't drawing any highs to them then actually they are working about the same or less because now you are playing only a limited number of tones...
AmBo
1,027
New Jersey
Mar 5, 2004
#18
  • Mar 5, 2004
  • #18
interesting
  • dan50
  • Jul 18, 2026
dan50
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Progress Thread severe97's Project Thread!
  • severe97
  • Jan 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 1, 2025
severe97
O
Resolved New here, bad electrical problems
  • Oxfordwhite01gt
  • Oct 12, 2023
1996 - 2004 SN95 Mustang -General/Talk- Oct 14, 2023
Oxfordwhite01gt
O
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
