Hello I need help please, I’ve been experiencing overheating issues, the needle can sit right in the middle at idle and as soon as I drive it will spike all the way to red (270). I don’t hear any bubbling coming from the radiator though, however; once I pull over the car will hesitate to start, slow crank until it cools down. Here is what I’ve done to it:
I recently refreshed the engine with GT40 heads, truck flow stage 1 cam and lower/upper explorer intake, headers and straight pipe. It has a new motor raft 180 thermostat, new SVE radiator, new motorcraft water pump and the stock fan. The timing is set up at 12 degrees and I did let the radiator burp. I have also replaced the temperature gauge sensor and the air charge temperature thats right behind it. The coolant sensor is also fairly new.
I just replaced one O2 oxygen sensor that broke, with a motorcraft as well. What am I missing? I thought maybe the heater core is bad but then I have no leaks.
Lastly, I rebuilt the computer by replacing the capacitors and I also replaced the relay on top of the computer that was bad.
Any advice is greatly appreciated.
Thanks
Thanks
