DISABLING SEAT BELT CHIME?
vitesse06
49
1. Set the parking brake
2. Put it in Park (auto) or neutral (manual)
3. Ignition off, doors closed, lights off
4. Turn the ignition switch to RUN (or ON) position (Do not start car)
5. Wait until the safety belt warning light turns off (about 1 to 2 minutes)
** The next three steps must be completed within 60 seconds or the
procedure
will have to be repeated.
6. Buckle then unbuckle the safety belt three times, ending with it
unbuckled
7. turn on the headlights, turn off the headlights
8. Buckle then unbuckle the safety belt three times, ending with it
unbuckled
** After step 8 the safety belt warning light will be turned on for three
seconds
9. Within seven seconds of the safety belt warning light turning off, buckle
** this will disable the belt minder if it is enabled.... This is also the
procedure for enabling the belt minder if it is disabled.
---do you guys know if the same sequence will work from the 99-2004 mustang to the s197?:shrug:
for the 02, to do it temporarily, you can just push the seatbelt release button, and it thinks you clicked the seatbelt. i dont know about a permanent disable procedure :shrug:
I'll have to ask the same question.....why ????
If I'm wearing my belt and the passenger isn't ...then I have to pull all my savings out to replace the hood and the windshield because my passenger went flying thru the windshield and may have scuffed my hood. Don't you have a family or friends that actually care about you?? why don't you just drill a pinhole in your brakeline and see how far you can go??
