can you check top be sure your converter is locking up?
something is definately amiss...........
Now I'm not sure anymore. DMAN302 said:lines are acutally so erratic because the smoothing factor of #0 is being used the majority of pulls will look like that with that smoothing factor being used.
crazypete said:Well, I adjusted my rockers and went the extra 1/4 turn and then went a little further....added a shim on ones that had to go more than another 1/2 turn.
So the pushrods are really damn close ...maybe...Now I'm not sure anymore.
Would....4 extra degrees timing give me that 50 hp? I'll run 93 if I think it will get me
Hell, I'd bolt up my stamped 1.6 factory rockers if I thought it would make a difference.
I checked the stall speed tonight and I pegged the throttle from a dead stop twice and once with the brake method and only got 2000 tops........never had perfect traction. Maybe this is acting as a 2k stall then. It's just a tci streetfighter.
What can I do to check the valvetrain? Compression test?
I'll get specs on that cam tommorrow. Thanks for all the advice guys. I'm gonna advance my timing next step.
I 100% agree. 2000 dollars on parts, then you're gunna skimp 30 cents a gallon? Get ****ing real man.tording said:if your not willing to use 93 octane fuel for the timing because of money then maybe you should get a new hobby.
