crazypete said:Cam was degreed by scratching my head then lining up the dots. I had a degree wheel but did not know what exactly to do with it. Obviously it's supposed to bolt on the front of the cam but then it hits the crank, then there's some triangles that say open and close. Couldnt make heads or tails of the whole affair so I lined up the dots and verified my work by turning the engine over by hand and verifying non-whackage of pistons. I further verified it by the continued non whackage since last august and smooth idle , drivability, etc...
No offense meant here Pete, but you need to go back in and degree the cam in - it bolts to the crank by the way. This and valve train setup could be where your HP is hiding. How did you determine pushrod length?
