Discharging your a/c
  • Thread starter Thread starter junkstang95
  • Start date Start date Sep 9, 2004
junkstang95
24
Tampa
Sep 9, 2004
  • Sep 9, 2004
I searched the forums, but I didn't find anything on discharging your own a/c. I have a 95 cobra 5.0 and I need to discharge the system. Is this done by the lowport or the high port. Also, is there anything special I need to know or consider. You can respond like I am a complete moron because when it comes to the cooling system...I am. Thanks to any replies in advance.
giddyup306
3,041
Sep 9, 2004
  • Sep 9, 2004
You need a recycle/recovery machine. Although you can illegaly vent it to atmosphere.
junkstang95
24
Tampa
Sep 9, 2004
  • Sep 9, 2004
Not that I would do anything illegal, but if someone were to do something so very wrong,how would they go about it? I didn't think r134a was bad for the environment.
88hatchblack
163
Willard, Ohio
Sep 9, 2004
  • Sep 9, 2004
you would have to accidentally let all the pressure out of the system via the schrader type valves with the motor running
D
Daggar
3,902
  • Sep 9, 2004
--or--
You can go to a parts store and pick up a couple of refridgerant reclamation bags. They're cheap (but can sometimes be difficult to find). You put them over the shrader valve then open em up. Seal the bag and drop it off to any reclaimation site (anyone who services air conditioners).
junkstang95
24
Tampa
Sep 9, 2004
  • Sep 9, 2004
Ah, yes....reclaim bags....thank you. Now after doing this is the recharge canister w/oil in it sufficient to replace the oil that is lost during discharge?
Ray III
586
fixin Boomhower's John Deere in Troy, NY
Sep 9, 2004
  • Sep 9, 2004
are you actually disconnecting something or what is your reason for discharging it?
junkstang95
24
Tampa
Sep 9, 2004
  • Sep 9, 2004
No I went to recharge it because I have a slow leak, but the pressure gauge says it is already full, and my air is very warm. So I wanted to discharge it and make sure that it is empty and then try and recharge it. I don't have the funds to take to a shop right now.
Ray III
586
Sep 9, 2004
  • Sep 9, 2004
then it should be fine to get a can of R-134a w/ oil in it and charge according to the directions...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 10, 2004
#10
  • Sep 10, 2004
  • #10
Before you do anything, make sure the heater flapper valve isn't allowing hot air to mix with the cold air. Most of the A/C systems use a knob connected to a cable operated flapper valve to mix hot & cold air. Once you know for sure that the heater isn't putting warm air in the A/C, then think about what to do next.
If an A/C system is charged without being vacuumed down first to remove the air, it will read full of refrigerant when it isn't. That's the problem with DYI air conditioning work. Most folks don't have a vacuum pump or a set of charging gauges to properly service the system.
junkstang95
24
Tampa
Sep 10, 2004
#11
  • Sep 10, 2004
  • #11
I discharged it and then used a few cans of refrigerant and now it will make your fingertips numb. If it gets warm again, I will go ahead and try the dye can and try to find the leak.
D
Daggar
3,902
#12
  • Sep 10, 2004
  • #12
If it does it again... take it someplace to have it vacummed down. In addition to what jrichker what talking about, there's a possibilty that you've got too much oil in the system. Sucking it down will remove the excess and allow room for the refridgerant. The dye is always a good idea, even if you don't suspect a leak.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
Electrical 1986 Mustang GT Multifunction Switch Question
  • Willybill32
  • Oct 26, 2025
Fox 5.0 Mustang Tech Nov 22, 2025
Willybill32
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
