  • SN95 4.6L Mustang Tech
disconnecting alarm system
  • Thread starter Thread starter moosewilsn
  • Start date Start date Oct 20, 2005
M
moosewilsn
17
  • Oct 20, 2005
I have a '96 Mustang convertible with an stock Ford active (vs. passive) alarm system. I can't just disconnect the alarm system in the trunk because it disables the car.
The reason I want to take it off is that it goes off anytime the car gets wet. The Ford dealer can't figure it out, and they don't know how to disconnect the alarm system without harming the function of the car.
Does anyone know how to specifically disconnect the alarm system?
I get sick of having to disconnect the battery to everytime I stop the car, and and then reconnecting it to start it again.
HELP!!
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Oct 22, 2005
  • Oct 22, 2005
shouldnt there be a fuse somewhere??
MGSTANG
383
Palm Bay Fl
Oct 22, 2005
  • Oct 22, 2005
It still won't work, it's got a starter kill. So when the alarm is either interupted or going off the car wont' start.
M
moosewilsn
17
  • Oct 23, 2005
alarm system - how do I unplug it!
I wish it was that easy. I was told that first, and I tried removing all kinds of fuses, but that doesn't work.
Any other ideas?
M
moosewilsn
17
  • Oct 28, 2005
If anyone can just tell me which wires to cut, or disconnect, or bypass - ANYTHING!!!!
streetstang03
unModerator
Dec 27, 2003
Oct 28, 2005
  • Oct 28, 2005
i bet the computer is programmed not to allow the car to start if the alarm has been dis-engaged (assuming the car came from the factory w/ an alarm). its near impossible to steal our stangs w/o the key, so it wouldnt surprise me if Ford did something like that.
M
moosewilsn
17
  • Oct 28, 2005
I had a reply from one guy from Italy that I probably need to get in touch with. If you are a car thief, apparently, it's easy. It's a ford stock alarm, and it's "active" whatever that means. There has got to be a way to disengage it. The thiefs have it figured out - I need someone from our group to figure it out. CALLING ALL CAR THIEVES - PLEASE DISENGAGE MY ALARM!!!
crazynorwegian
20+ Year Stangneter
Nov 6, 2003
267
azusa, ca
Oct 28, 2005
  • Oct 28, 2005
you dont have to disconnect the battery every time you leave the car. just lock the doors manually, (dont use the remote and dont use the power locks). this will keep the alarm from turning on passive mode.
MGSTANG
383
Palm Bay Fl
Oct 29, 2005
  • Oct 29, 2005
U have to take it somewhere to get it removed. That's all I can say
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
D
Fuel 1985 GT Fuel Line Diagram
  • DienstXIV
  • Apr 17, 2025
2K
Fox 5.0 Mustang Tech Jul 12, 2025
DienstXIV
D
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
