- Jun 2, 2005
- 584
- 3
- 19
I installed my 5.0 H.O. into my T-Bird (1988) last June.When I pulled the engine from the LSC,I never pulled the distributor,not even when I put the Explorer intake on.I did remove all of the wires at once though.Well,when I put the wires back on,the ignition module now has to be touching the thermostat housing to run decent.It was pointing to the front left of the car.I installed the #1 wire on the #1 position on the dist. cap,and wired it right (351 order).Could the cap actually be wrong?Do I need to move all of the wires over one way or the other?Lastly,do I have to pull the little pip before I move the distributor,then re-installit?How exactly does that work.Thanks guys.
