dist. gear broke
  • Thread starter Thread starter 11sec87
  • Start date Start date Nov 25, 2006
11sec87
161
ill
Nov 25, 2006
  • Nov 25, 2006
After about 5 hours run time, my dist gear wen
t south. I replaced the whole dist. with a MSD billet, and that gear is showing some wear after about 3 hours. I have 30lbs pressure at idle, with a hi volume mellings. Any one had a prob with dist gears?
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Nov 25, 2006
  • Nov 25, 2006
what kind of gear is on the distributor? is it a brass gear? also, what kind of cam are you running...roller or non roller
11sec87
161
ill
Nov 25, 2006
  • Nov 25, 2006
crane .573, retro roller(sounds gooood), hardened steel gear.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Nov 25, 2006
  • Nov 25, 2006
thats wierd. i wonder if the cam is walking back and forth and causing the problem. maybe someone who builds lots of engines will chime in.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 25, 2006
  • Nov 25, 2006
I've always read that you need a bronze gear with a roller cam, although I've never heard much of an explanation as to why? How do the teeth on the cam look?
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Nov 25, 2006
  • Nov 25, 2006
the bronze gear will wear out quickly with a roller cam. you can run it but it wont last long. a hardened steel gear is what is recommended. id say that the cam is walking forward and putting too much pressure on the distributor gear causing it to wear out...but thats just me
11sec87
161
ill
Nov 25, 2006
  • Nov 25, 2006
If I didn't know it was a hardened steel gear, I would not believe it. each tooth is
'cut' in the contact pattern of the cam. A couple teeth finally broke causing no spark. Thats when I found the problem.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Nov 25, 2006
  • Nov 25, 2006
somethings not right with the cam...dont run the car until you figure out whats wrong. all those metal shavings are not gonna be good for the motor if you just keep putting new dizzy gears in it. maybe rick will come tonight and give some advice
11sec87
161
ill
Nov 25, 2006
  • Nov 25, 2006
Already flushed the engine withfresh oil acouple times, changed filters, magnets on the pan and a pair of magnetic plugs trying to catch the trash.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Nov 25, 2006
#10
  • Nov 25, 2006
  • #10
good stuff....now we just need a second opinion. can you see down in there and see what the cam shaft looks like? maybe its messed up or it was screwed up from the factory and the gear is too big on the end of it....i dont know
11sec87
161
ill
Nov 25, 2006
#11
  • Nov 25, 2006
  • #11
Cam looks fine. No broken teeth. Edges on the thrust side are still sharp. Acts like it still hasnt mated to the dist. gear.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Nov 25, 2006
#12
  • Nov 25, 2006
  • #12
really wierd....i dont know what to tell you man. but ill keep bumping it until we get an answer
is the dizzy sitting all the way down. there isnt any rtv or anything keeping it from sitting flush with the block?
11sec87
161
ill
Nov 25, 2006
#13
  • Nov 25, 2006
  • #13
Dist. sits fine. Ran for hours, not like it's a hard bind. Had someone suggest toooo much oil pressure during a fresh startup. 30 lbs at idle 60 at 5500 does notsound unreasonable for a fresh motor. I figured too much endplay on the originad dist. (factory unit) but the billet is still showing a "shiney" wear pattern. Im afraid to keep running it just like you said.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Nov 25, 2006
#14
  • Nov 25, 2006
  • #14
no thats definetly not too much oil pressure for a fresh start up or a broke in motor for that matter. hell my bosses drag car sees 80 psi of oil pressure and his oil pressure gauge is hooked into the back of his head after the oil goes through all the rocker arms. so hes probably seeing 100 psi of oil pressure and he doesnt worry about it
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Fox Power Loss While In Gear
  • J_5.0_VERT
  • Dec 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2024
J_5.0_VERT
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
