Dist. removal question
  • Thread starter Thread starter diablostang
  • Start date Start date Sep 23, 2005
diablostang
425
Raleigh, NC
Sep 23, 2005
  • Sep 23, 2005
I've got to replace my head gaskets, so obviously the Distributor has to go... I searched around, found a tutorial that said-
"Place the distributor rotor pointing to the #1 cylinder, that's around 1 o'clock. Mark the relationship of the rotor to distributor using a marker pen. Remove the retaining bolt and lift the distributor out. Remember NOT TO CRANK the engine !!"
I know this is a stupid question, but I need to know
How do I turn the dist. rotor to the #1 position? And where do I need to mark the relationship between the rotor and dist?
Again, I'm sorry to ask the stupid questions I appreciate any help
Oh and if anybody has any pix, they'd be very helpful.
RYC CUKR
1,437
Orlando
Sep 23, 2005
  • Sep 23, 2005
I have always used a 1/2" breaker bar to rotate the engine around to #1 positionon the dist. I can't remember what size socket you need but you put it on the balancer bolt and use the breaker bar or ratchet to rotate the engine around to the desired distributor location.
diablostang
425
Raleigh, NC
Sep 23, 2005
  • Sep 23, 2005
Perfect, thankyou!
Now what exactly do I need to mark?
THanks!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 23, 2005
  • Sep 23, 2005
Take the coil wire out of the distributor. Pull #1 plug, put your finger in the spark plug hole. Have someone crank the engine until it starts to blow air past your finger. Stop cranking, turn the engine by hand (15/16" socket on a breaker bar on the harmonic balancer bolt, or put the car in gear and push) until the TDC mark on the harmonic balancer lines up with the pointer on the passenger side of the engine. Loose the distributor hold down bolt, remove the clamp, cap and wires, disconnect the wiring harness. Pull the distributor straight up.
The following re-install depends on the engine being lined up as in the previous instructions.
To re-install, turn the distributor rotor to point to #1 cylinder position on the cap. The#1 position is about 12 o'clock if 6 o' clock is the front of the engine. Line the rotor up with it pointing at the #1 spark plug position on the cap and drop it in: you may have to twist the shaft some to get it to engage the oil pump shaft. Then remove the SPOUT connector plug, and use a timing light to set the timing. The SPOUT is the dangling connector on the distributor harness on stangs made prior to 94 and with a computer controlled engine. 10* is stock for most 5.0s' 12*-14* is good for more pep if you are not into NO2 or power adders.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
  • dan50
  • Jul 18, 2026
dan50
