Distribution block
  • Thread starter Thread starter 2nd Mustang
  • Start date Start date Apr 9, 2007
2nd Mustang
2,488
Southern California
Apr 9, 2007
  • Apr 9, 2007
In an attempt in finding out what is causing my front discs to lock up, I'm down to the last item, the distribution block. There are so many different size nuts on the hard brake lines at the distribution block and master cylinder.
My car is in the storage yard right now and I've been going back and forth to see what lines and size nuts I might need because I'm sure I'll destroy some nuts trying to remove them from the old distribution block. (I'm past the laughing stage.) Now I find out the top rear nut on the distribution block will require a 7/16" nut (wrench size) and a 1/2" nut at the MC end. I can only find the 7/16" nut in a 1/4 inch diameter size brake line, but I'm sure all the hard brake lines are 3/16". Anyone have a clue?
2nd Mustang
2,488
Southern California
Apr 10, 2007
  • Apr 10, 2007
FYI.
I did a google search last night and the only 7/16" brake line nut I could find was for a 1/4" tube and I need something for a 3.16" tube.
Stopped by an all Ford wrecking yard today and found tons of master cylinders and distribution blocks in a big pile. After a minute or two, I found that elusive 7/16" nut for a 3/16" brake line, and the best part, it was free.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Apr 10, 2007
  • Apr 10, 2007
If u need any more check a parts store called OReillys; they have a huge selection of fittings and tubing.
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
P
Transmission to radiator connection
  • P0nyRider
  • Aug 5, 2024
1996 - 2004 SN95 Mustang -General/Talk- Sep 23, 2024
4gwenddolau9
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
