distributo cap problem
91lxntch
247
altoona,p.a
heres the low down on my problem...
every cap and rotor i run that has brass (2 msd's/2 accel's) burn out within min's and causes a bad miss up top but everytime i through a stock fomoco from advance on the car runs great no problems what could cause this to happen should i try drilling a few holes in the side of my msd cap to release air....
The brass caps and rotor will wear much quicker then the Ford Stainless models, it is even worse with with high powered ingniton modules. The last MSD cap I saw or used already had the vent in the top.
ok, thanks for clarifying. i once managed to actually melt the rotor in half (the end of it where the conductor is, was almost melted off). not real sure what i did. (not on a stang). :)
Rick, you said what i was thinking. a harder metal (stainless or whatever else) will not theoretically conduct as well, but will suffer less erosion and degredation. did you get your blower yet?
i am aware of that so far but will they really burn out within like 5 mins and yes all that i have tried are matched sets i just replaced a arcing coil would that cause it..also could it hurt to drill a few small holes in the side to let air excape
