Distributor & Balancer Install
buckshot1020
I have a longblock ready to go in my 89 Notchback. The distributor needs to go in as well as the balancer. Questions:
1)At what point does the balancer go on in the cycle of the engine?
2)Easiest way to get TDC of #1 cylinder?
3)Once I have TDC of the comression stroke on #1, I can just rotate the rotor to the #1 wire and stab it then set timing.. correct?
Thanks people!
Put the balancer on before you put the engine back in the car. It is much eaiser to get to the balancer bolt with the engine out of the car. The only problem with it out of the car is keeping the crank from turning when you tighten the bolt.
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole, crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing. If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that if it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back in when you finish.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
attachment.php
