I was timing my car today and my distributor gear felt funny so I looked at it and the teeth look thinner then before, and there was also lines on the bottom of the teeth where it was thicker. I compaerd the gear to the gear on my mallory unilite and the unilite gears are thicker and have flat spots on the top of the teeth. The teeth on my dist now (stock ford) come to a point. What is going on? Should I be worried? Btw, cam is a comp solid lifter that is mabey 4 months old. Thanks, mike.
if that is case you have another problem somewhere, possibly the distributor shaft is slightly bent or your timing chain is worn out causing the cam to "rock" back and forth so to speak, for lack of a better term. it is also possible that the cam was hardened differently than it should have been creating an incompatibility with cast gear, kind of a stretch but it is possible. the best thing i can tell you is to call comp and see if the cam you have is supposed to use a special gear, IIRC some solid cams require a bronze gear
