  • 1994 - 1995 Specific Tech
Distributor gear question!
  • Thread starter Thread starter 69clark
  • Start date Start date Jun 7, 2006
69clark
731
Ravena, NY
Jun 7, 2006
  • Jun 7, 2006
Trying to get all the final peices together to complete my build up. My question is do I need to replace my dizzy gear? I have read that I should with a brand new cam (roller). If so what kind do I need? I have also read that it needs to be brass for a roller cam, is this correct? Also I am running the stock dizzy and the gear on that doesn't seem to be brass, it is black in color. Is there anything else I should know?
:SNSign:
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 7, 2006
  • Jun 7, 2006
:SNSign:
If it's brass (copper/zinc), a magnet will not stick to it.
I am running the stock dizzy w/ my new tfs stg1 cam. Never heard that the dizzy needs to be replaced. I guess there could be some gear meshing issues but IMO highly unlikely.
Scott
94gts
873
Carmel, New York
Jun 7, 2006
  • Jun 7, 2006
you need a different dizzy gear with solid roller cams and thats it
69clark
731
Ravena, NY
Jun 7, 2006
  • Jun 7, 2006
maybe I was unclear, I need to know if I need to replace the gear.
69clark
731
Ravena, NY
Jun 7, 2006
  • Jun 7, 2006
so not for a hyd. roller cam.
94gts
873
Carmel, New York
Jun 8, 2006
  • Jun 8, 2006
maybe i was unclear?
no
HISSIN50
34
129
Jun 8, 2006
  • Jun 8, 2006
AFAIK, we use a steel gear stock. Brass is some soft stuff - You lost me with what you are going to do cam-wise, but really nail that down before using it.
I'd check with the cam manufacturer to be sure.
Good luck.
Zero Signal
2,633
Tucson, AZ
Jun 8, 2006
  • Jun 8, 2006
As long as the distributor gear is softer than the cam steel. The idea is for the dist. gear to fail and not the cam since the dist. gears are easy to replace. With that said, I wouldn't mess with special hardened steel dist. gears. The stock one should be fine. If it wears too quickly, then maybe step up to a harder gear and re-check to make sure the cam is ok later on. I noticed that my dist. gea has a lot of wear for only having about 100 miles on it. I still need to call MSD and Comp to see what their recommendations are.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
