Im doing the 5.0 swap.. Do you have to take the distributor to a machine shop to get the gears on the distributor swapped?
jae902 said:My msd came with the bronze gear, i don't want to buy another gear cause i'm broke as it is. The motor i have is a roller cam block, can i just take the gear off the original distributor that came with the motor and swap it?
D.Hearne said:When yuo swap gears, yuo really don't want to try and line up the existing holes on the dist shaft and gear. With a replacement gear, you drive the gear onto the shaft and drill a new hole thru the gear and shaft at 90 degrees to the old one. Then install the roll pin.
I wanted to use a steel gear, but I was told that the Chet Herbert solid roller cam required a bronze gear. I checked it after about 2000 mi of street and track driving (4:11 gears and HV oil pump) and found no unusual wear. I guess they got it positioned correctly on the distributor shaft. However, I would have been happier with a steel gear if I could have used one.gp001 said:I would not put on a bronze gear. For a roller use a steel gear. I originally put on a broze gear cuz that's what some people recommended, but after ~750 miles the gear stripped. Driving down the freeway with my buddy behind me. He said it looked like a battle ship firing. There was a HUGE BOOM and then nothin. When I talked to CHP about it they said use as steel. Bronze is good for a race engine that gets checked/serviced regularly, but being so soft it will not last long under normal driving conditions
The steel gear I replaced it with has gone 14k miles. I have pulled the distributor and inspected both the gear and cam at 5k, 7k, 10k, 13k, and it neither show signs of wear.
Here is a pic of the cast iron gear (new, never used) and the stripped bronze gear.
Because the new gear has no holes in it. And if swapping gears from one dist to another, chances are if you do get the holes lined up. the dist gear will not be in the correct location on the shaft and you'll end up with binding gears or premature wear.jae902 said:Why wouldn't you want to use the existing holes?
If you want a bronze or brass gear, then by all means, go ahead and get one. Just rememeber what us, who advocate using steel gears told you, when that bronze gear strips when you're out cruising in BFE in the middle of summer and it's 110 degrees outside.
Just common sense will tell you that a brass or bronze gear will wear faster against a steel camshaft than a matching steel gear will. D.Hearne said:Cause they're still of the mind set that roller cams are just for racing.If you want a bronze or brass gear, then by all means, go ahead and get one. Just rememeber what us, who advocate using steel gears told you, when that bronze gear strips when you're out cruising in BFE in the middle of summer and it's 110 degrees outside.
If your gear was the steel one and only lasted that long, then you either installed it incorrectly or it was defective. You cannot use the .531 gear in place of the .467 If your dist shaft was a .467, the .531 gear would just fall onto the shaft. You say your oilpump is a HV unit, how much pressure does it put out. I'm using a Ford Racing HV pump and my cam gear and dist drive shaft have worked flawlessly for two years now. My oil pressure hot or cold at 2000rpms is 70-80 psi. If you've gone thru 2 dist gears, what does your cam's gear look like now? Or have you checked it?66Stanger said:Hi guys !
I've '66 Mustang with 332 stroker and E303 cam.
First gear dead at 800 miles (FMS-M12390B 0.467").
Second gear dead at 60 miles only !
Maybe the good choice is FMS-M12390F (0.531") ??
I use a HV oil pump from Milodon, is it the cause ??
Please let me know your opinion about it.
