hummer784 said:
Could someone please explain distributor phasing to me? I understand the purpose, but how do I do it? Thanks, mike.
Some can call me Bill and some can call me Will but its all the same to me...
Phasing is simply an offbeat pseudonym for timing.
1. Locate TDC of the compression stroke for #1 cylinder.
2. Mark timing marks on harmonic at desired timing point (usually 6 degrees BTDC).
3. Mark distributor case where #1 spark plug wire plugs in cap (centerline of electrical post).
4. Rotate engine to timing mark on harmonic.
5. Remove distributor cap, loosen distributor and turn until rotor aligns with mark on distributor case (step #3 above). If vaccuum advance diaphragm prevents full movement, lift distributor, and drop back in at gear tooth where rotor will allow easy adjustment of distributor before and after mark (step #3 above). When rotor is exactly aligned on cap post for #1, car is timed.
6. Reinstall cap and tighten distributor.
7. Validate timing with timing light (vaccuum advance disconnected and plugged, engine rpm at lowest obtainable rpm or 600 rpm). Light should flash directly on timing mark (see #2 above).
