Engine Distributor Question
Vettn71
Advanced Member
Jan 3, 2014
273
154
74
I know I’ve seen this somewhere, but ......
I have an 85 motor (roller) with a B cam. I want to use the stock distributor from an 84 302 in this motor. Is there a problem in ,atching these two up?
TIA
Jim
I guess I shouyhave mentioned it’s an auto with Eli. My understanding was that flat-tapper engines could not use the distributor out of a roller engine. Thanks for the response. I need to slow down and get everything down
Jim
The roller cam needs to have a steel gear.
If you’re running efi I would just get a distributor for a 86-93 mustang, that would be ideal.
You can get a rebuilt stock dist for quite cheap.
