Engine Distributor Shaft
  • Thread starter Thread starter rotorhead22
  • Start date Start date Jan 24, 2024
First Prev 2 of 2
TOOLOW91
20+ Year Stangneter
8,760
234
S.I.NY
Jan 26, 2024
#21
  • Jan 26, 2024
  • #21
I don’t think the extra length is going to effect or not effect anything . When you order an aftermarket one for argument sake besides 351 vs 302 and gear material no one mentions the length of the shaft.
I have to agree I think it’s for ease of dropping in to engage the oil pump . If the hex is on the shaft it’s in . I’d run the 85 and not look back .
Well I’d keep it fuel injected but that’s not what we’re talking about. LOL
Reactions: limp
85GTStangGuy
5 Year Member
May 19, 2021
1,008
631
133
Jax, Florida
Jan 26, 2024
#22
  • Jan 26, 2024
  • #22
Me - "A carb swap doesn't require a distributor change."
AeroCoupe said:
If he had an EFI distributor I am pretty sure he needed to swap it for a regular distributor ....
Noobz347 said:
This is what I recall:
The EFI distributor gets swapped for a carb distributor
The shaft [length] and [diameter] are different for a carbed distributor and EFI distributor....
Dammit, I got that one wrong. You guys are absolutely correct.
85GTStangGuy
5 Year Member
May 19, 2021
1,008
631
133
Jax, Florida
Jan 26, 2024
#23
  • Jan 26, 2024
  • #23
rotorhead22 said:
..... Old on right. ..... <<MISSING PIC!!>>>
Fyi, referencing your pic in the quoted post (post #3) (the pic wouldn't copy over in the quote), on my never-installed, remanned, spare Ford distributor, which supposedly is specifically for an '85 carbed 5.0, the length of the shaft below the gear is 1.55". Being a reman though, I have no idea how that actually compares to the stock (still installed) distributor.
AeroCoupe said:
..... but the 85 GT distributors are hard to come by.
Would this work?
https://lmr.com/item/LRS-12127BK/Mustang-50-Distributor-Steel-Gear-1985-Carb-Only
AeroCoupe said:
Another thing I came across is that the longer shaft in the roller motors was to ease the installation of them on the assembly line. The longer distributor shaft engages the oil pump drive before the distributor gear contacts the cam gear so it makes it easier to install. From that I took it that there is no other benefit.
Ahhh.... I was wondering why they'd be different,,,, that sounds like the dealy there.
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,517
2,938
173
Florida
Jan 26, 2024
#24
  • Jan 26, 2024
  • #24
That is the LMR Distributor in my Explorer engine using my 83 intake.... I have a DUI on order if it ever comes....
cbac89
22
Raleigh, NC
Sep 11, 2024
#25
  • Sep 11, 2024
  • #25
I know this is an older post, but what did you end up using for the distributor and coil?
Reactions: nickyb
rotorhead22
175
89
38
Wesley Chapel, Florida
Sep 12, 2024
#26
  • Sep 12, 2024
  • #26
1985 manual transmission with steel gear and stock 89 coil. Amazon A-Team ready to run
cbac89
22
Raleigh, NC
Sep 12, 2024
#27
  • Sep 12, 2024
  • #27
I did some testing with other units i had from my 74 302 build and i have a Pertonix D130700, which Summit says will only fit 82 and prior engines.. Im wondering if this is because of the shorter shaft. I dry fit it and it goes in, and i get spark. I guess i need to make sure the oil pump shaft engages. Im using a flame thrower coil as well.
General karthief
Mod Dude
Aug 25, 2016
28,105
10,716
213
polk county florida
Sep 12, 2024
#28
  • Sep 12, 2024
  • #28
It probably has the wrong gear on it, 74 used a flat tappet cam
Reactions: limp
cbac89
22
Raleigh, NC
Sep 12, 2024
#29
  • Sep 12, 2024
  • #29
I updated the cam on that engine. The D130700 does have a steel gear though, but i cant figure why non of the catalogs say it wont fit an engine after 82. It may be because it says it will not work with a computer controlled vehicle (?).
First Prev 2 of 2
P
Engine Swapping EFI distributor for carb distributor- shaft length is different
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 21, 2024
pindude80
P
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Need Some Dyno Video File Sizes
  • Noobz347
  • Jan 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 20, 2025
TOOLOW91
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
