distributor wires
  • Thread starter Thread starter spade33
  • Start date Start date Jul 16, 2007
spade33
198
Tempe, Arizona
Jul 16, 2007
  • Jul 16, 2007
ok so i just got a new distributor so i was just curious if someone could help me wire the spark plug wires up, i know where the number one cylinder is on the block but i dont know where to put it on the distributor itself, how do i wire the wires on the distributor where is number one on the distibutor and how do i wire them up the old distributor was wired up wrong so i am starting from scratch...i hope that makes sence
rbohm
6,698
550
204
tucson,az
Jul 16, 2007
  • Jul 16, 2007
first bring the number one cylinder to tdc compression stroke. then drop in the new dist, and line the rotor up with a terminal on the new cap. this will be your number one terminal. it doesnt matter where it is, as long as the dist is wired correctly.
spade33
198
Tempe, Arizona
Jul 17, 2007
  • Jul 17, 2007
thank you very much i got them wired up and i am just getting all the connections good so hopefully it will be started again thank s again
D
D.Hearne
11,730
south louisiana
Jul 17, 2007
  • Jul 17, 2007
The wire sequence is counter clockwise on the distributor cap.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Can anyone identify this connector?
  • 74delta
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
Qtrhrse23
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
