  • 1994 - 1995 Specific Tech
Distributors
  • Thread starter Thread starter 95BLKGT5.0
  • Start date Start date Sep 7, 2007
1 of 2 Next Last
95BLKGT5.0
608
Auburn Washington
Sep 7, 2007
  • Sep 7, 2007
Distributor opotions?
My car cuts out every now and then so I replaced the coil and check all the ground wires but still cuts out so I think the PIP is going bad. There are 122000 miles on the distributor so I think the best thing to do would be to get a new distributor.
What good Distributors and price are there.
I plan on rebuilding the motor next year.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 7, 2007
  • Sep 7, 2007
Stock Ford unit....MSD makes one that fails often enough to make me not even consider it. Some have had no problems but there are other who are on there 2nd and 3rd ones from sudden failure. I think performance distributors (they make Live wires) make a 94/95 unit but haven't heard anything about them.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Sep 7, 2007
  • Sep 7, 2007
I was gonna say the exact same thing. I have an OEM replacement and its fine.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 7, 2007
  • Sep 7, 2007
Well Danny
They don't call that company
Mignt Suddenly Die
for nothing
Grady
HISSIN50
34
129
Sep 7, 2007
  • Sep 7, 2007
If you get one from the parts store, it will probably be reman'd. When they take in cores, if the old PIP tests ok (wanna take bets how thoroughly it's tested?), they often leave it on there. If a new PIP is installed, they often will not take the time to line up the holes for the roll pin. They punch a new hole instead. So a tell is to see if there's a blank hole in the dizzy shaft. If so, the chances of it having a new PIP are decent.
Good luck.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 8, 2007
  • Sep 8, 2007
final5-0 said:
Well Danny
Mignt Suddenly Die
for nothing
Grady
yeah Grady that name fits nicely. JT I won't take that bet I fold lol.
95BLKGT5.0
608
Auburn Washington
Sep 8, 2007
  • Sep 8, 2007
Thanks for the info guys.
HISSIN50
Great info
"So a tell is to see if there's a blank hole in the dizzy shaft. If so, the chances of it having a new PIP are decent"
I will make sure to check that out.
1TallMF
955
Montreal
Sep 8, 2007
  • Sep 8, 2007
I got a reman last month, and now the car runs better than ever. Timing is set the same as before (~12*) and now I can run 87-octane without pinging. It used to ping quite often with 94 in it, and to top it off I now manage 26-27mpg on the highway
Only bad part is that they didn't put a heat shield over the PIP wires coming out of the dizzy, so they're just bare at the moment.
9
95steeda
37
  • Sep 9, 2007
distributor
Hello, I had the same problem. Car would die for no reason; stoplight, normal driving, or full throtle. It wouldn't do it all the time though. Changed fuel filter, fuel pump, cap and rotor but none of those changes fixed it. Then changed the distributor, runs great now. Like the previous reply, it also fixed my detonation problem with lower octane gas, for a while. But overall, its alot better. An OEM could be had for $80 or so. Or you could replace the stator assembly thats on the distibutor. Thats probably the part that is bad. That part is $20 or so.
MisterCMK
20+ Year Stangneter
Oct 2, 2004
201
Fargo, ND
Sep 9, 2007
#10
  • Sep 9, 2007
  • #10
Just bought a reman from O'Reilys myself due to a bushing that died in mine at 157,000 miles. The damn thing died on me this morning on the interstate with 15 miles on the new one. PIP sensor went out. I had to get a ride back home and get my buddy and my truck to tow my car off the interstate. I put the old dizzy back in and it started right up. Lets just say that I will be have a few "choice" words with the auto parts store.
mustang6tee8
375
College Station, TX
Sep 9, 2007
#11
  • Sep 9, 2007
  • #11
Good luck.
I put a remaned dizzy in my 95, but my engine would still randomly die. It ended up being the TFI module (TFI=thick film ignition), located on the passenger side inner fender under the MAF. Might want to get it checked out.
HISSIN50
34
129
Sep 9, 2007
#12
  • Sep 9, 2007
  • #12
And you are who?
Wade brings a good point. This is where some differential testing can help.
M
mojopony
71
#13
  • Sep 9, 2007
  • #13
When my original stock distributor gave up the ghost in my '94 GT the rotor hit the cap and the innards all broke up into pieces. When I pulled off the highway (rolled off the highway actually) I came to a stop on a side street so I hopped out and took a look under the car and my cats were glowing bright orange. I have a re-mfg. unit in there now.
1TallMF
955
Montreal
Sep 10, 2007
#14
  • Sep 10, 2007
  • #14
I might also note that when my PIP went, the car just bogged a couple times then died completely, never to be resurrected. It would not start the next day either after a complete cool-down. As for TFI modules going, I have seen them die then work again once they had cooled-off. A good check for this is to look for injector pulsing when the car dies and won't fire. That will distinguish the problem from being PIP or TFI related, or even something else.
95BLKGT5.0
608
Auburn Washington
Sep 16, 2007
#15
  • Sep 16, 2007
  • #15
Well I got a reman dizzy and timed it with the spout out @10deg.
Ran Great and did not miss a beat. The next day it did not want to start right away, It cranked and cranked then I stopped turned the key again and it started fine. then this morning it would not start just keep cranking over but would not start.
95BLKGT5.0
608
Auburn Washington
Sep 16, 2007
#16
  • Sep 16, 2007
  • #16
Thank you HISSIN50 for the info on the dizzy. At the NAPA parts store I looked through 5 boxes and of the 5, 3 were the wrong dizzy but labeled as a 95 Mustang the other 2 didn't have the extra hole drilled. So they had the wearehouse look through all theres and shipped me one.
95BLKGT5.0
608
Auburn Washington
Sep 16, 2007
#17
  • Sep 16, 2007
  • #17
This is the ingnition kit I have
5.0 Dyna-Mod
The 5.0 Dyna-Mod has more electronic dwell in it over a stock module to provide more coil saturation time. This extra dwell time allows the coil to produce a more intense spark. Improves throttle response and low end power. Mounts in the original factory location without any modifications.
Part #000555 (84-93) $69.95
Part #X000555 (94-95) $69.95
Screamin' Demon Coil
Open up spark plug gaps to a whopping .060" with the Screamin' Demon coil. No drop off in power as RPM's increase. The coil has a brass terminal, rather than aluminum, which provides better conductivity and will resist corrosion longer. This coil is too "hot" for stock plug wires.
Part #31724 $69.95
5.0 Cap and Rotor
Super conductive brass terminals deliver ALL of the spark to the plugs. Excellent dielectric strength resists carbon tracking. Available in red or blue. Part #34100 $35.00
Livewires
go-stang5.0
2,244
Glenview,Il
Sep 17, 2007
#18
  • Sep 17, 2007
  • #18
I bought my msd 3-4 yrs ago when I did my motor....it still runs great. However theres no benifit except it looks pretty. I guess I lucked out that mine still works good. If this one goes I will prolly try a performance distributors one as a new ford one is pretty pricey too. I think I will stay away from reman. ones all together.
Z
zZsKyZz
503
Sep 17, 2007
#19
  • Sep 17, 2007
  • #19
Mallory might make one... I don't buy anything MSD anymore.
I work at an auto parts store and MSD/Superchips have it set up so we CANNOT sell any of their products below MSRP.
Normally dealers, employees, and my select friends get a "Jobber" or a better price that our warehouse/supplier buys the product for. MSD/Superchips does not allow this.
So for now on, they don't support me--I don't support them.
I won't even suggest their product to anyone, nor will anyone I work with. If someone looks at a 6AL or 6A, etc... Product by them I tell them that their product will fail out of nowhere, their warrenty process sucks, and that they can get a better product for a fraction of the cost.
Methodical
1,192
11
59
Clinton, MD
Jan 22, 2008
#20
  • Jan 22, 2008
  • #20
I currently need a new distributor. My MSD has a bad stator/PIP/pickup/hall effect (whatever it's called now). It began its demise back in August 07 (misfires). Car sat for a minute and now it's gone. Car starts then immediately dies. Checked ignition system and no sighal to PIP from stator. Sad thing is I only have maybe between 1K-1.5K miles on the distributor - if that - as I only drive the car on the weekend occassionally. The MSD 6AL is hanging in there though (over 10 yrs.)
I understand the stock is good for N/A but is it a good idea to go aftermarket if running 150 shot of N20. Plus, I was just quoted $440 for a stock distributor. Hell aftermarket is cheaper now. So now I think Ford's pricing is forcing aftermaket purchases. Plus based on Hissin observations, the reman can be just as troublesome.
So what'ya think - aftermarket for 150 shot of N20
Thanks
1 of 2 Next Last
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
M
Running rough
  • Mike3
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 1, 2026
Mike3
M
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
