  • 1994 - 1995 Specific Tech
dizzy/timing q's
  • Thread starter Thread starter Hef5.0weisen
  • Start date Start date Aug 3, 2005
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Aug 3, 2005
  • Aug 3, 2005
Searched around, here's what I got. Stab the dizzy w/balancer at zero, rotor pointing to #1 on the cap. Verify, by poking in the #1 cylinder, should touch the piston head. Allright, car should fire up like that, yeah? Read something about checking for spark at the cap...never did it....insulated tool close to one of the posts on the cap, while cranking? Anyway car won't start, checked all the connections again, got fuel, worked before I took it apart. I know it's spark related, just chasing it down now. Any pointers welcomed...let me know...thanks
to clear things up, how would you initially stab a dizzy?
how do you check for spark at the cap?
illwood
636
Worcester, MA
Aug 3, 2005
  • Aug 3, 2005
Well, you're on the right track. Air, fuel, spark, and compression are the magic ingredients for a running engine.
- Did you check your firing order and that your plugs are wired correctly?
- Does the coil have power?
- You can check a plug by putting a spare plug in the boot and grounding it on the engine or chassis and have someone crank it and you should see spark.
BTW, what mods were you doing that required you to pull the distributer out? Could other mods be your real gremlin?
HISSIN50
34
129
Aug 3, 2005
  • Aug 3, 2005
and even if the car is out of time, you should have spark. If you have clearance to spin the dizzy while getting it in time, just spin it till it is in time (no such thing as being one tooth off - that is an internet myth).
The exhaust stroke will also push a little bit of air out the plug hole and the car will run on the exhaust stroke (just barely or sometimes not at all). So making sure you are on the compression stroke is useful.
Good luck.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 3, 2005
  • Aug 3, 2005
Check for spark at the cap by unplugging the coil wire at the cap. Then just lay the wire near some metal and crank the car to see if you have spark. Of course you need a friend to do the cranking. You can do the same to see if you getting spark at any of the plugs as well.
CManT1914
3,172
Killeen, Texas
Aug 3, 2005
  • Aug 3, 2005
With the cap on, I marked the bowl of the distributor where #1 point was. The rotor will spin clockwise as you set it in, so you need to turn it to where it's about 1/8 of the way BEHIND (counter-clockwise) of the #1 spot. Then make sure you are on TDC of the compression stroke. If your valve covers are off, you can watch to see when both valves are closed, then just leave it there until you're ready to set the timing, or you can just stick your finger in the spark plug hole and feel for the piston. Then there's no reason related to timing (assuming you have adequate spark as others mentioned) that the car won't start. You mentioned you have fuel, so it should work. Just keep trying, it took me about a dozen times restabbing the dizzy to get it to fire after my h/c/i swap.
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Aug 3, 2005
  • Aug 3, 2005
I got it,thanks all
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
  • dan50
  • Jul 18, 2026
dan50
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
