  • 1994 - 1995 Specific Tech
Do I even need C/C plates?
  • Thread starter Thread starter The Green GT
  • Start date Start date Sep 1, 2006
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Sep 1, 2006
  • Sep 1, 2006
I just lowered my car a few weeks ago. I got it aligned afterwards and told them to get the C/C as close to perfect as they could w/ the stock plates casue I was getting some adjustable ones soon. Well yesterday I was getting a price for my exhaust and the guy who did the alignment was telling mew that he dosent think I need them becasue he got the drivers side perfect and the passenger side in the good area. He dosent think Ill need them, what about you?
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Sep 1, 2006
  • Sep 1, 2006
You've got H&R Supersports, so I'd think you would be lowered around 1.75" to 2". That usually requires aftermarket C/C plates to get the alignment set dead on.
However, your shop said you were really close on one side and good on the other. For me, I would want both front tires dead on. A good alignment can help in many ways which may be worth the $$$ for new C/C plates: tire wear, bumpsteer, trameling (sp?), gas mileage, street handling, etc.
MM has C/C plates for $199.95 and they've worked well for me. Just depends on how accurate you want to be. You could have your alignment checked at another reputable shop in a couple months and see what they say. I found out where a lot of local Vettes in my area go for alignments and that shop has been good.
Methodical
1,192
11
59
Clinton, MD
Sep 1, 2006
  • Sep 1, 2006
How low did you go? My understanding is that 1/2" to 3/4" don't require CC plates. Did he get it close to stock settings which by the way would not be good if the car is very low. I ask this because when I first lowered my car, the alignment guy said he got it close to stock parameters. But the negative camber was very noticeable to my eye and my pockets after I had to buy new tires. For me stock setting would not be good. But I'm over 2"s down. Eyeball the tire from the front to see if they have very noticable negative camber (i.e. top of tires tilt towards engine bay). You can get away with negative 1* of camber. To me if it's really noticeable with the nacked eye, then it needs attention. Better safe than sorry.
Peace
The Green GT
1,269
Louisiana
Sep 1, 2006
  • Sep 1, 2006
Im more than likely still going to get them. I could literally see the passenger wheel was slanted when was done lowering it. I was going to gett the C/C plates next but I think Ill get the gears first
The Green GT
1,269
Louisiana
Sep 1, 2006
  • Sep 1, 2006
Peace
I cant notice anything, except on the passenger side I can notice it in the right light, its not bad at all.
Im dropped about 2 inches so thats why Im confused as to how they got it so straight w/o notching the plates.
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Sep 1, 2006
  • Sep 1, 2006
I would get C/C plates if my end game was a tighter overall suspension, regardless of spring capacity and drop.
The "street" says you only need them when you drop over 1 inch and other suspension mods are not in your plans.
HISSIN50
34
129
Sep 1, 2006
  • Sep 1, 2006
I kinda agree (this is why I only have a Prokit drop). The thing is that even the stock suspension settings were bland and could be improved upon when in stock form (dialing in some caster, etc). So if you just want decent tire wear, you might be alright (if your alignment guy said things were copacetic). But for optimal handling, you'd want the plates.
I like your plan to get them, funds allowing (had I the funds, I've have them on both stangs).
Good luck.
The Green GT
1,269
Louisiana
Sep 1, 2006
  • Sep 1, 2006
Good luck.
They were going to be the next thing on my car, but since I wont destroy my tires by not getting them, and it handles great right now, Ill get the thing I really need next. I cant wait for the gears.
TheDamned
"I am Canadian and Damned for it!"
Jul 22, 2003
457
Montréal, Québec, Canada
Sep 1, 2006
  • Sep 1, 2006
You will need 'em sometimes soon anyway.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Sep 1, 2006
#10
  • Sep 1, 2006
  • #10
If they wear then get them, if not don't worry about it. With my C springs it wasn't really necessary since the drop is minimal. I have Pro3i 4 bolt plates now but only swapped to those when I changed the struts, bump steer kit and k-member.
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Sep 1, 2006
#11
  • Sep 1, 2006
  • #11
GET THEM...im on sportlines which are a very simliar drop to the supersports, and i ate through my front 2 tires in a matter of months...then i installed them and got an alignment, and the uneven wear ceased....
fwiw, become a member of corral.com (free) if your not already, and u get a member discount on MM c/c plates which i have...i think i got them for like $179 shipped....
timeless2
Admin Dude
202
154
the Shadow Gallery
Sep 1, 2006
#12
  • Sep 1, 2006
  • #12
Keep your biz with StangNet, if you go the CC route. Give us a call and see what kind of deal we can make for you.
http://www.partshopper.com/shop/Pro3-Caster-Camber-Plates-79-04-m134.html
http://www.partshopper.com/shop/Steeda-Aluminum-Caster-Camber-Plates-79-04-m136.html
http://www.partshopper.com/shop/Steeda-Caster-Camber-Plates-79-04-m135.html
9
93GTWannabe
81
Norfolk/Houston
Sep 1, 2006
#13
  • Sep 1, 2006
  • #13
I had a '99 that was dropped about 2- 2 1/2 " and it ****ed tires up left and right... i lowered my '95 that i have now, and it's dead on, and never got it aligned, as for the '99, i had the shop i worked at do the alignment, and got it as close to good as i could, sold it before i got CC plates, I plan on getting them for the '95 just because i plan on installing Coilovers, and lowering it more later than it is now... i would do it, just to be safe down the road. in my case anyways, if your shops says it's good, get the alignment paper work and look for yourself.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 1, 2006
#14
  • Sep 1, 2006
  • #14
Problem is that if the tires wear uneven, you have to throw them away. Once they wear uneven, they will not straighten back out once the alignment is fixed.
You can't adjust caster with the stock plates, which is why you need the CC's if it's off. And you may be reaching the limits to the adjustments in the camber/toe department, which necessitates the cc plates again. Do it once and be done with it.
Scott
P
Pennywise2
Banned
May 16, 2006
1,379
#15
  • Sep 2, 2006
  • #15
If you are considering C/C plates.
The Steeda and Maximum Motorsport C/C plates are both good choices.
Afterall aftermarket C/C plates make for the perfect alignment on
a lowered car.
M
MustangGT95
407
#16
  • Sep 2, 2006
  • #16
I would get a set. If he got it within acceptable range then the plates really won't help any. Because all they can do is try to set it to factory specs. There are no specs for lowered vehicles.
But i would still do everything as "right" as possible.
When I got my truck it was lowered 6'' in the front with cut springs. The wheels sat like this / \ it was bad. I decided to fix it whenever I wore a tire threw on the inside edge.
Now I have 3'' belltech springs and 2'' spindles. Rides really good now. And I got a pretty decent alignment. But you can get a lot more camber adjustments on s10's because of the "shim" setup.
C
ccramer
14
New Jersey
Sep 3, 2006
#17
  • Sep 3, 2006
  • #17
The Pro3i plates will do more than allow you to align the car. The benefits are increased caster for straight line control and better cornering with less static negative camber. You also eliminate the big mass of rubber on top which will help with predictability and better and quicker turn in as well as your alignment not changing during hard cornering. They will also allow you to raise the strut in the bearing which gives you more suspension travel on a lowered car. These are the ones I would get http://www.partshopper.com/shop/Pro3...9-04-m134.html.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
