I lowered my car about two months ago using the B springs (got about an inch at all four corners), and everything runs fine. The car deosn't pull left or right at any speed, nor at braking. However, I do believe that my toe camber (if that's the right name) is bad. The reason is that the front wheels are leaning towards the inside of the car a little bit. I don't want uneven tire wear, nor an unsafe car, so I figured I'll need an alignment.
I was wondering if a shop can fix this with the standard setup, or if I'll need to spend more money and get those plates?
