do i need to break in my new cam?
Always, always, always lube a cam and the lifters (if they are rollers) when you install them. You don't want a dry lifter and a dry cam rolling on eachother. Dry = friction. Friction = Kaboom. They have a lube specifcally for lubing a camshaft, and I believe it's called cam lube. :D. 30 wt. oil works well for our hydraulic lifters.
Joe
Joe
I disagree. On a flat tappet cam it is understandable. On a roller cam it is different. You have to allow all cams a break in period. The point of not using the lube on a roller is so the rollers actually DO roll on the cam. If you lube the SCOOT across the cam lobe and do not allow a proper breakin. ONLY on a roller cam. I have heard this my whole life, and read it in tech manuals.
