Do I need to replace bearings on gear install ?
danny04GT
50
Phoenix
OK.. I'm finally ready to order my 4.10 gears :D The shop I was going to have install them said that if the car has over 40k miles, they insist on changing the bearings. I have 36,000 miles and they said if the bearings look worn, they will need to replace them and the bearing kit is 120.00 additional. What do you guys think? Should the bearings be replaced at 36-40k miles or is this shop full if it?
I think you should show them this link and tell them they're going to have to price match if they want you to change them!
http://www.mustangtuning.com/rearendrebuild.html
28 spline.
i would only get motive if you want a gearset that FRPP doesnt make(IE 3.90's). otherwise just get the FRPP's if youre looking into the 3.73/4.10's, as the Motives are more sensitive to a bad install than the FRPP's.
im getting 3.90's cause i cant decide between 3.73's or 4.1's, so im getting motives. nothing wrong with that, i just have to make sure i take it to a shop that knows their ****.
thomas91169 said:
28 spline.
Yeah, i'm sure FRPP will be better quality, i'm just thinking the FRPP set 200 + 120 for the ford bearing kit = 320. The Motive gears set with the bearings is $100 less.
