do it your self media blasting
  • Thread starter Thread starter snowb07
  • Start date Start date Apr 24, 2004
snowb07
235
soon to be CT
Apr 24, 2004
  • Apr 24, 2004
I would like to media blast my car my self and wondered if anyone has don this/ what media you used and wher eyou got the stuff from,.
thanks
-fred
RajunCajun
180
  • Apr 24, 2004
Almost all major rental places have units available some self contained (meaning it has its on compressor and motor to power it) and just sand blasters with no motor that you must hook up to a compressor. They usely have media available there also by 100lbs
hope that helps somewhat
R
Ronstang
1,294
Houston Texas
Apr 24, 2004
  • Apr 24, 2004
You can buy a decent pressurized sand blaster for $100-150 and do it yourself. I used sand for mine. Don't worry about all the naysayers commenting on how sand with warp your body.....it will, but using the kind of compressor most have at home you will be blasting at such a low pressure that it is a non issue. Even my 5hp 60gal compressor gets choked to it's knees by a sandblaster and the most I can sustain is about 20psi which isn't enough to cause the heat needed to damage the sheetmetal....unless you just shoot it at one spot for a long time. Simply keep moving and hold the sandblaster nozzle as parallel to the sheetmetal as possible while still actually doing something. I have blasted both my 57 T-Bird and 66 Fastback this way with no damage whatsoever and saved a ton of money.
You need to wear earplugs to keep the sand out of your inner ears. You should also wear a face mask to keep from breathing the silica dust as much ass possible. Get some screen material and a funnel to strain the used sand and reuse it so you don't have to buy tons and tons of sand. You are always going to lose some and it gets progressively smoother but I always reuse mine as much as possible. Be prepared to spend a lot of time chasing the sand out of every crack and crevice though. Get a good etching sealing epoxy primer and paint the car immediately after finishing so you don't have to redo it.
Dark Knight
2,578
Chandler, Az.
Apr 25, 2004
  • Apr 25, 2004
I got the sand at home depot, pretty cheap
the prob I had was keeping air pressure up... the normal home sized compressor doesnt have a big enough tank to last long
also, if you do it in the driveway, plan on having sand EVERYWHERE.. I'd sweep what I could up, strain it.. and use it again...
I skipped the ear plugs and got a hood used in clean rooms..
worked pretty good, ended up taping some of the vent holes in the safety glass because sand still found a way in..
xoxbxfx
3,959
Southlake, TX
Apr 25, 2004
  • Apr 25, 2004
Im not a big fan of sandblasting a car due to the mess. You will have a nasty sandstorm and sand will be all over your driveway/grass/house/car. Everything will get covered. If you do do it, I suggest a full face mask (like a welding helmet), dust mask, hat, earplugs, long sleeve shirt. You get the idea.
I would look into soda blasting. You can usually rent the machine for around $200 and the media you will use will cost about $40. The stuff just needs to be washed off and neutralized (use vinegar) and you have a nice clean car. Not to expensive.
1320stang
4,329
23
89
Edmond, Oklahoma
Apr 25, 2004
  • Apr 25, 2004
If you can find a place that dry ice blasts, now that is da bomb. No media to clean up and no warpage problems. I'm just not sure how it does on rust.
snowb07
235
soon to be CT
Apr 25, 2004
  • Apr 25, 2004
well I am not to worried about sand everywhere I in Clovis NM and with the wind and sand already here no one will be able to tell,
Also is the sand used just normal sand, if so can I just sweep it up and shot it ,,
-fred
R
Ronstang
1,294
Houston Texas
Apr 25, 2004
  • Apr 25, 2004
Sand blasting sand is basically normal sand that has been filtered so it of a certain size and it has been dried so it does not clump and clog the device so it blends in real nice with the landscape.
Edbert
3,548
32
109
Austin TX
Apr 25, 2004
  • Apr 25, 2004
Hehe, I don;t think the humidity in Clovis will give you any trouble. Herer in Austin I had a few issues. Whatever you do not not underestimate how big of a mess you'll make. I spent as much time getting sand out of spots as I did blasting it in the first place
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
Staytuned stock bottem end build...
  • rednotch
  • Dec 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 13, 2025
G
2005 Mustang GT AC cycling on and off every minute
  • GeorgeSwadling
  • Jul 12, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 12, 2025
GeorgeSwadling
G
Help Reading CEL Light
  • Mhalc1
  • May 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2025
Mhalc1
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
