  • SN95 4.6L Mustang Tech
do it yourself speedo correctioon
  • Thread starter Thread starter crimm99
  • Start date Start date Jun 2, 2004
C
crimm99
41
Clinton, IA
Jun 2, 2004
  • Jun 2, 2004
do it yourself speedo correction
Has anyone ever corrected there speedo themselves after a gear install? 99 and newer mustangs come with a built in diagnostics tool, check it out here
http://www.mustangworld.com/ourpics/fcar/dtcodes.htm You can get a digital readout of how fast you are going. My question is after a gear install would that digital readout be off to? If not you could set the cruise at 55 or so pop of your speedo needle, it would probably be reading 80 or 90, and put it back on 55.
Blev
1,295
So. Cal. V-Town
Jun 2, 2004
  • Jun 2, 2004
Won't work. The speed is affected incrementally and the different gear ratio changes the way it reads it. So popping the needle off won’t solve your problem. I’m not sure about the accuracy of the digital read out though, I would think that would be off too.
GTvert01
636
West Plains, MO
Jun 2, 2004
  • Jun 2, 2004
I think that both would be off too.
M
moreause
74
  • Jun 2, 2004
both would be off, because the digital and and needle are taking there reference at the same place. At that is a the exit of the transmission.
So if nobody tell the computer you have change the gear the number will be off. Unless you trick the number between the trans and the computer...like with a speedcal
twogts4us
4,188
12
79
Dunedin, FL
Jun 2, 2004
  • Jun 2, 2004
The digital readout would be off too.
Plus, are you serious about popping the speedo needle off while driving at 55MPH?
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
  • dan50
  • Jul 18, 2026
dan50
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
