Do you guys think i'll have piston to valve clearance with this setup (351w)
I was just curious if those more experienced engine builders would think if I'll have a problem with this setup
351w block
flat top pistons with 4 2cc valve releifs(deck milled)
62cc world windsor sr iron heads (milled from 64cc) with 2.02/1.6 valves
10.49:1 cc with a .039 head gasket
the cam is a lunati 41008 solid flat
290/300 adv dur.
249/258 dur @.50
.54/.544 lift with 1.6 rockers
I have 1.72 rockers so my lift will be .581/.585
108LSA with a 104 ICL
With 2.02 valves you're really gonna need a small cam, to not have to worry about the pistons kissing the valves. :D "If you want to play, you've got to pay" :D Now on my 331, even with the Canfield heads milled .060, and a .587 lift 228 degree cam (@ .050) I've had no issues with 1.94 valves. Most pistons only have reliefs for up to 1.94's. Only some have them to accomodate 2.02's
