You can always use the clay method it is very easy. Just install the cam, line up the timing marks with crank, install a piston into the block, coat the valve reliefs with some oil (So the clay won't stickand ruin accuracy of reading), put two small pieces of clay in the valve reliefs, put the cylinder head on, now if you have a hydraulic cam insert solid lifters into the corresponding bores(a regular hydraulic lifter will collapse so you must use or make a solid lifter, I made two with JB weld), put the cylinder head on with rocker arms, then crank the engine over a couple of times, and then take everything off along with the clay CAREFULLY and measure it with a micrometer and there you go you have your clearance. Or you can also do it with a magnetic base and dial indicator to measure valve travel.
