Do you have to O-ring the block if you have O-ringed heads?
I do know for sure, If u want to get technical we can. High HP drag cars o-ring the block and the heads, but for you, o-ringed heads will be fine. If you buy a set of o-ringed heads, you just need a matching head gasket and your set.
Thank you sirsureshot...Now do you know of any good brands of head gaskets that are for O-ringed heads? BTW: the heads in question are the stock E7TE heads that have been O-ringed...this is why I wasn't sure if it would be cost effective to machine the block to be O-ringed while running OEM heads...Thanks bro... :nice:
When you O-ring the heads, and you have a problem and the heads come off and need to be shaved for flatness... the o-ring reciver groove has to be machined back in the heads... More Money. and the O-ring gaskets are pretty expensive each time!! O-ring the block is a one time deal... its done!! the gaskets can be any where from stock to copper and the seal is great!! And when there is a problem, the heads can be surfaced flat and the block will still be fine and the gaskets are 40-50% cheaper... just a thought!!
But.... NO !! there is no special prep for the block to run o-ringed gaskets!! However the block should be true in any case..cool??
Just me.................................
Thumper
sirsureshot39 said:
my heads were bought that way from Trick flow. The gaskets are from summit
and your block is completely stock with the stroker or is it like a sportsman block? No machining? How are you not blowing head gaskets with so much power if your block is not O-ringed? I guess those head gaskets must be pretty tough...how much are they if you remember? Good set up... :nice:
