Oh ok. I misunderstood you at first. I think if you change over to the SN-95 stuff then you will need to change over your brake lines to work with the new calipers.
The brake hoses will need to be from an SN95. I used MM lines which have the correct fittings, but if oyu decide to use parts store hoses, you will need an adapter for the passenger side. You can only buy this adapter from Matt90GT as far as I know.
Because the passenger side has a different size fitting on the soft line I believe, could be thhe hardline, but anyways the fitting is different. You could just buy SS lines from MM, and they bolt right in. Just make sure they are for a Fox using SN95 calipers.
I guess they don't have SN95 specific lines. I got the cobra ones for my cobra brakes, which have different banjo bolts. MY lines didn't have a huge block at the end, but rather a small circular end. If the 87-93 lines they offer are like this they will fit just about any caliper.
