dodge 1500 manual transmission fluid?
cooper
96
I would like to change the trany fluid in the wifes truck, but cant find any info on what it takes and how much of it! One guy at the store said it needs synthetic trany fluid but had no info on how much? Can any one help. Its a 2001 dodge ram 1500 V6 (3.8 im thinking) with a 5-speed manuel. Thanx
just the person I was looking for, I was going to pm you but my memory faded on your name!!!! ha ha old age is starting to creep up on me! thanks for the help..
Model Fluid Capacity
All Models: Capacities may vary. Correct fill level is to the bottom edge of the fill plug hole.
NV3500 2.28 L (4.8 pts.)
NV4500 3.78 L (8.0 pts.)
NV5600 4.5 L (9.5 pts.)
as far as the type of fluid it says to go to mopar and use mopar approved lubricant. ill make a few phone calls and see what i can find out.
the numbers nv3500 - - - is this on the sticker inside the door? Or on the trans? Mopar approved lube sounds pricey , and prob synthetic. Thanks I'll do a little looking on the truck for more info. Thanks , Coop
oops i almost forgot about this, had a realy great weekend! Well I looked at the door tag, its very ginarick. After the paint code it has a code TRM 59 AZ . Im only juessing the TRM stands for transmission? Dont know if this helps at all? thanks Coop
