Does anybody know...?
  • Thread starter Thread starter rod196202
  • Start date Start date Aug 20, 2005
R
rod196202
44
  • Aug 20, 2005
Im changing R&P to 3:73s does anybody know what size rearend is on 93 vert. with aod is it 7.5?? thanks
sunil6784
620
Boston, MA
Aug 20, 2005
  • Aug 20, 2005
8.8 rear end most likely with 2.73 gears
giddyup306
3,041
Aug 20, 2005
  • Aug 20, 2005
Look on the tag on the pumpkin. Most likely 2.73s as stated.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 20, 2005
  • Aug 20, 2005
If it's a 5.0 it's a 8.8
D
Daggar
3,902
  • Aug 20, 2005
Unless it's 85 or older.
R
rod196202
44
  • Aug 20, 2005
Its a 5.0 so it is 8.8 30 tooth spindle?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 20, 2005
  • Aug 20, 2005
nope....8.8 28 spline.
vristang
4,933
101
124
Seattle
Aug 20, 2005
  • Aug 20, 2005
According to my Reference guide 93 5.0 Drivetrains are as follows
5spd manual Standard2.73 Optional 3.08
4spd auto Standard2.73 Optional 3.27
I assume by 93 all Mustangs had 8.8
The tag on the rear (assuming it is still there) will give better/more reliable info though.
Good Luck with the gears.
R
rod196202
44
  • Aug 21, 2005
ok i was looking on summit ford raceing 3:73s 8.8 had 30 spline will this work???
vristang
4,933
101
124
Seattle
Aug 21, 2005
#10
  • Aug 21, 2005
  • #10
I don't see how the axle spline count will affect what gears you need.
Can you post the link to the summit gears?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 21, 2005
#11
  • Aug 21, 2005
  • #11
I think that's the entire rear end that he's looking at.
You can just replace the ring gears alone. All you need are 3.73's for an 8.8 rear. Spline counts don't matter. SHould be about $120-190 for a set of Ford gears
R
rod196202
44
#12
  • Aug 21, 2005
  • #12
http;//store.summitracing.com/ part#fms-m-4209-f373n
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 21, 2005
#13
  • Aug 21, 2005
  • #13
Those will work.
I dunno why they say 30 spline...spline count doesn't matter.
R
rod196202
44
#14
  • Aug 21, 2005
  • #14
Mustang5L5 said:
Those will work.
that helps thanks
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
W
fuel pres reg bolts
  • waxman
  • Dec 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 5, 2025
AeroCoupe
Drivetrain Witness marks on Torque Converter
  • Mcmahst
  • Mar 19, 2025
Fox 5.0 Mustang Tech Mar 21, 2025
85GTStangGuy
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
