i have the trick flow track heat package on my car and i hear a whiseling vacuum leak or howling sound coming from around the plenum somewere. i think this would cure my weird idling problems.
To help find vac leaks you can spray starting fluid in the area of suspected leaks. When the starting fluid enter the intake via the vac leak the engine rpms will increase. Be carefule where you spray though, this is flammable fluid.
A vac leak can cause idle problems. Are you using a large aftermarket Throttle Body? My BBK TB makes a pretty lound whistle. Other than the noise it causes no problems.
Mine ocassionally has a whistle however no vacuum leak. By the way I have a track heat with 1" phenolic spacer and need a strut tower brace that will clear it, any ideas?
Maximum Motorsports seems to give the best clearance for all the intakes I've seen. I don't have one yet(tranny started acting up) but I am in the same boat as you. Check them out at www.maximummotorsports.com
Kevin
