does anyone have this problem??????
jimc347
77
i have the trick flow track heat package on my car and i hear a whiseling vacuum leak or howling sound coming from around the plenum somewere. i think this would cure my weird idling problems.
To help find vac leaks you can spray starting fluid in the area of suspected leaks. When the starting fluid enter the intake via the vac leak the engine rpms will increase. Be carefule where you spray though, this is flammable fluid.
A vac leak can cause idle problems. Are you using a large aftermarket Throttle Body? My BBK TB makes a pretty lound whistle. Other than the noise it causes no problems.
try this brace
mike0227 said:
Mine ocassionally has a whistle however no vacuum leak. By the way I have a track heat with 1" phenolic spacer and need a strut tower brace that will clear it, any ideas?
take a look at this brace I have it on my car and it works great... it links right with the stock brace... giving it lots of support...
click on the link
http://www.wmsracing.com/pgi-ProductSpec?WMS-STB79M
