Does anyone here have a tko-500
driveshafts are the same for fox and sn95. I have a FMS aluminum and still used a 5/8" spacer when I installed the TKO. The tranny sits that much further up towards the front of the car when using a TKO or fox style tranny/bell.
I guess if the driveshaft was made for your application then it'd be ok, like maybe one for the '94/5 cobra R.
i've never heard of a longer driveshaft that motorsport makes so that the spacer isnt needed, and you dont need a new driveshaft, just a new yolk for the tranny end of the driveshaft with the correct spline. depending on which model TK500/600 you get will determine what clutch disk you need.
miller92063 said:
what modification needs to be made to the crossmember?
Dont modify your crossmemeber just buy an Offset trans mount and it will be one million times easier. I got mine from www.bieberfever.com. I did mine about 3 months ago. Here is what i needed
Bell Housing, TKO-500, Fox Clutch Fork, Offset mount, 31 spline slip yoke, DS spacer, 3 quarts of GM Syncromesh.
