  • SN95 4.6L Mustang Tech
Does anyone make....
  • Thread starter Thread starter notched86
  • Start date Start date Jan 4, 2004
notched86
305
Ruckersville, VA
Jan 4, 2004
  • Jan 4, 2004
An eaton supercharger or kit for 96-98 Mustangs? I'm not lookin for big power, just something that looks clean and installs easy. And of course that sweet blower whine the eatons make.
stangtrooper97
322
King of Prussia
Jan 4, 2004
  • Jan 4, 2004
Ford Racing has a kit for the 96-98 GTs. They say it is good for 55 horsepower at 6psi boost. Many people have it and swap a 9 pound pulley onto it and put down some decent numbers. It is a good blower to use everyday cause it is reliable and alot of fun.
skywarp
379
  • Jan 4, 2004
Do they make one for 99+?
PezKing
55
middletown, DE
Jan 5, 2004
  • Jan 5, 2004
still waiting for a 99+ kit.... from the looks of the 96-98 kit, the price is right for a little extra everyday "umph" for those of us that can't make it to a KB just yet;-)
Wills Black 98
2,455
Western North Carolina
Jan 5, 2004
  • Jan 5, 2004
dont buy the ford kit, spend your money and buy a good blower it will probably be cheaper and defiantely produce better numbers!
VTEngine
364
Lansing, MI
Jan 5, 2004
  • Jan 5, 2004
allen engine development has kits as well
stangtrooper97
322
King of Prussia
Jan 5, 2004
  • Jan 5, 2004
Oh yeah, i forgot about AED.
blown96bird
17
  • Feb 1, 2004
allen engine makes a great blower setup.
allen engine
check out the power I am making with my allen it has a lot of mods over a standard allen kit. check out the link to the video of my dyno run
my allen
I strongly recomend that you purchace a 90 mm lightning from dan newman for joe cooper ford in mid west city oklahoma you can buy it with out paying a core charge and it will be 100.00 I also recomend that you purchase a 70 mm frpp throttlebody along with a set of 30# hr injectors and a chip from sct.com.
The reason to upgrade is that the power and throttle response will be much better. The FMU is a band aid. The factory mass air meeter will be maxed out and the injectors are not big enough to deliver enough fuel at stock fuel pressure. I strongly recomend reading the article over on tccoa.com about the alen. The ditching of the fmu will give you 25 hp over using the fmu.
The reason why I recomend adding a 70 mm tb is that it will give you 10 hp over the 65 mm unit. The opening in the inlet is 67 mm so you will need to purchace a rotary file and open it form 67 mm to 70 mm no big deal. If you need a set of 30# hr injectors I have a used set that I will sell for 100.00 compared to the cost of new ones of 260.00 + Check out tccoa.com I also recomend that you ditch the mechanical coolant pump and spend a little extra and upgrade to a lightning coolant pump.
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
