Does check engine light normally come on when you turn ignition to accessory position
johnny_261
42
Hey Everyone,
My 89GT recently stopped running. It's very strange because I haven't done anything with the car at all. I went to start is about 3-4 weeks after the last time I ran it and it won't start. The engine cranks but it won't start...
The check engine light comes one when I'm trying to start the car as well as when I'm in the accessory position. Is this normal? I know in my other car, the check engine light comes on when you're starting it up, but I couldn't remember for this car.
Should I get a code reader?
Also, before I start trouble shooting, does anyone have any suggestions to get me started. I wouldn't think it would be anything major like a fuel pump failure etc. because the car was fine a couple weeks earlier, and had started fine for the last year.
Thanks for your help!
Thanks for the help. I used the paper clip method and got the codes. I'm a little confused by what I got though. Could you please help interpret?
1 blink, 2 blinks, 1 blink, 8 blinks, 7 blinks, 2 blinks, 1 blink, 8 blink, 7 blink...long pause, 1 blink, 1 blink, 1 blink, 1 blink, 1 blink.
I have an 89, so I'm thinking it means
12, 18, 72, 18...but after this, I'm not sure...since there is a lone 7 and then 5 single blinks.
Please help!
As suggested...
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
