Does fuel tank baffle float?
  • Thread starter Thread starter turtleb
  • Start date Start date Aug 8, 2006
T
turtleb
PA
Aug 8, 2006
  • Aug 8, 2006
Does the baffle in the fuel tank float up and down on one end? I'm getting a tank from the salvage yard and one end is attached to the bottom of the tank and the other end is unattached. Is this correct or should both ends be attached to the bottom? Thanks......
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 9, 2006
  • Aug 9, 2006
they are attched when made, but it is VERY common for them to break loose - mine is.
T
turtleb
PA
Aug 9, 2006
  • Aug 9, 2006
So both ends should be attached? The people at the salvage yard are saying only one end should be attached. If one end is already detached, I don't want the other end detaching and destroying my fuel pump. Should I just buy a new one and skip the one from the salvage yard?
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Aug 9, 2006
  • Aug 9, 2006
Ive ran my car for four years with a detached baffle, same pump never changed.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 9, 2006
  • Aug 9, 2006
mines' been loose for who knows how long
QDRHRSE
1,590
Palmdale, CA
Aug 9, 2006
  • Aug 9, 2006
It's not a big deal.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Aug 9, 2006
  • Aug 9, 2006
how can you tell when they come loose
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 10, 2006
  • Aug 10, 2006
When the tank is almost empty (like when you go to replace a pump) you can hear it slide around as you remove and handle the tank. Then, when you remove the pump bung, you can see the baffle and move it around.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 10, 2006
  • Aug 10, 2006
A clean, empty tank and some JB weld epoxy will fix the problem with the loose baffle.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 10, 2006
#10
  • Aug 10, 2006
  • #10
jb weld adhesion will live submersed in gasoline?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 10, 2006
#11
  • Aug 10, 2006
  • #11
I have heard of it being used to patch gas tanks.
Edit: I did a Google search and found there are a whole world full of people who have used it for that purpose.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 10, 2006
#12
  • Aug 10, 2006
  • #12
good to know, thanks!
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Aug 10, 2006
#13
  • Aug 10, 2006
  • #13
would you be able to hear it when the tank is full. I have some noise when I hit bumps when going real slow (on a sand beach) and I always thought it was the exhaust swinging side to side a little
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 30, 2026
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
