Does hot tanking clear cooling passages?
68conv4sp
270
Is there an acid in the hot tank process that will completely scavange the inside of all cooling passages? I ask because if I go to the expense of pumping up my 289, I want to be sure that it has crystal clear cooling passage walls.
I'm pretty sure that hot tanking will in fact clear out the cooling passages. If it doesn't, then a good thorough steam cleaning should do the job. Best way to find out is to ask the guy that'll be doing the job.
good choice on pumping up the 289.
Thats what I thought. I assume that most water jacket deposits are calcites, so they should react with acids. The hot tank process looks like it strips hydrocarbons only.
