  • 1994 - 1995 Specific Tech
Does MSD make a difference????
  • Thread starter Thread starter Pokageek
  • Start date Start date Jul 18, 2006
Pokageek
2,767
MA, USA
Jul 18, 2006
  • Jul 18, 2006
Has anyone felt a seat of pants difference with this or DYNO? I felt a noticeable harder pull along the entire rev range on my 90 GT with a considerably better pull in the higher RPM's with a similar Crane HI-6. I have also heard of sn95's having problems with the crane..and maybe MSD.. Any ideas?
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jul 18, 2006
  • Jul 18, 2006
i have had the 6al in my car for 3.5 years now with no problems. as far as a seat of the pants gain though, i dont know. i put the msd in when the car was fairly stock and the upgrade was unnecessary so it didnt make any noticeable difference to me.
BlackVert
5,589
9
98
Bethesda, MD
Jul 18, 2006
  • Jul 18, 2006
it would probably be most noticeable with blown apps where spark blowout is more common. n/a i doubt it would be noticed much
cobra259
152
Waterford Mi
Jul 18, 2006
  • Jul 18, 2006
You are correct..I picked up 9HP and 11tq at the wheels with my MSD6a
Pokageek
2,767
MA, USA
Jul 18, 2006
  • Jul 18, 2006
Is it that the spark in the sn95 is superior to the 90-93? Otherwise, I can't explain why it made such a nice difference on my 90.
krahkin
183
Acworth GA
Jul 18, 2006
  • Jul 18, 2006
I run the Crane Hi-6 on my 95 and noticed a massive improvement. Haven't been back to the dyno since the install, so I can't say for sure what the gains are. From 4k+ it is SOTP different though.
OrangeMustangGt
1,976
Cape Cod, MA
Jul 18, 2006
  • Jul 18, 2006
what do these actually do? i've never been able to get a straight answer....i wonder if it would help me
parchisi
519
New Mexico
Jul 18, 2006
  • Jul 18, 2006
Instead of one spark to ignite in the combustion chamber, it sparks several times in rapid succession for a better ignition. Hence, MSD = Multiple Spark Discharge. An aftermarket coil will increase the intensity of the spark. Correct me if I'm off my rocker, but that's what i've been lead to believe.
HISSIN50
34
129
Jul 18, 2006
  • Jul 18, 2006
That's correct. Some folks swear by them while others notice no difference. On foxes, dyno runs have shown the stock ignition to hold up to almost 400 HP N/A. Like said, power adders almost definately require a box. Anytime something's done to change cylinder pressures, significant stiochiometry changes, etc, it's a good idearrrrrrrr.
For a mild NA combo, I personally feel that if the stock ignition is up to par, differences felt shouldnt be huge. One thing's for sure - it cant hurt.
Pokageek
2,767
MA, USA
Jul 18, 2006
#10
  • Jul 18, 2006
  • #10
Makes sense. I have hear the following many times:
"On foxes, dyno runs have shown the stock ignition to hold up to almost 400 HP N/A. "
I understand that it holds up but can it perform "better"...I am leaning toward getting one considering my personal experience and a few you guys. My 90' just ran better with it, snappier off the line, swept better throughout the RPM range and harder pull to the red line. It was completely stock but for exhaust.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 19, 2006
#11
  • Jul 19, 2006
  • #11
I gotta side with JT on this one
If your stock oem ignition system is in good shape
and
You be a NA kinda guy
The gain is gonna be small ... if any ... with aftermarket systems
however
Our cars are gettin kinda long in the tooth
sooooo
Our oem stuff is most likely not as crisp as it used to be
Grady
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jul 19, 2006
#12
  • Jul 19, 2006
  • #12
did you make any other changes with the ignition such as the coil, plugs, and wires? if so, the replacement of older wearing maintenance parts may have been the cause of the noticeable difference.
Pokageek
2,767
MA, USA
Jul 19, 2006
#13
  • Jul 19, 2006
  • #13
No changes. I just plugged the new one in and wowee - made a significant difference. The car had about 26k miles on it at the time. I posted over in the older mustang section to see if there 87-93's showed a difference but no replies on it.
OrangeMustangGt
1,976
Cape Cod, MA
Jul 19, 2006
#14
  • Jul 19, 2006
  • #14
huh.....how can it really spark multiple times when your revving up near full throttle? there would seem to be no time at all.....?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 19, 2006
#15
  • Jul 19, 2006
  • #15
mine seems to rev a bit quicker, could just be in my head tho
1slow95
1,797
ohio
Jul 19, 2006
#16
  • Jul 19, 2006
  • #16
It does multiple spark up to 3000rpms I think, then it's a "single powerful spark" for anything over that.
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
