Does Size Matter?
  • Thread starter Thread starter abnovak
  • Start date Start date Jul 8, 2004
A
abnovak
28
  • Jul 8, 2004
Have a friend who has a 351 with a 14" K&N aircleaner but he likes the smaller 9" chrome air cleaner better. Will he loose performance going to a smaller size?
TheWolf
257
NC
Jul 8, 2004
  • Jul 8, 2004
If they're both the same type of filter, I don't think there'd be much difference at all. At least not that you could tell.
DarkBuddha
2,215
Seattle & Tampa
Jul 8, 2004
  • Jul 8, 2004
I doubt he'll notice any loss of performance, but theoretically, it is possible if the smaller air cleaner causes enough restriction to choke the carb. The 14" air cleaner provides for more surface, thus providing less restriction to air to flow to the carb. The formula for the circumference is 2pir so to get the area for each air cleaner, multiply the circumference by the height of the air cleaner. For example:
area for the 14" air cleaner =
* 3.14159
* 7" (half of diameter of 14")
* 3" (example air clean height)
= 131.94678" of area
area for the 9" air cleaner =
* 3.14159
* 4.5" (half of diameter of 14")
= 84.82293" of area
But, will he notice any performance loss? Probably not since it's doubtful the 9" air cleaner will cause enough restriction. Probably more consequential is that the K&N will outflow a normal paper element (which is a bigger restriction), so if the 9" is a paper element air cleaner, I say stick with the 14" K&N.
Hope this helps.
1969mach1351
285
Sacramento, CA
Jul 8, 2004
  • Jul 8, 2004
A 351 with a redline of 6000 RPM needs about 101 cubic inches of filter area. Like DarkBuddha said 14"x3" has 131 and the 9"x3" has 84. If he wants a 9" he will have to go with a 9"x4" which is 113 cubic inches.
WRXracer
825
  • Jul 8, 2004
ok
ill ask my lady tonight if size matters..
D
D.Hearne
11,730
south louisiana
Jul 8, 2004
  • Jul 8, 2004
If he goes with a K&N 9" diameter filter, then he'll lose nothing. I saw a test where they compared engine performance to filter size using K&N's and even with the tiny 4" filter, nothing really changed much as HP goes. There wasn't 10 HP difference from the smallest to the largest K&N. I believe the test motor was a Chevy 350.
67coupe351w
424
Portland, OR
Jul 8, 2004
  • Jul 8, 2004
Arent air filters rated in CFM? As long as the CFM is as big as your carb there wouldnt be any problem.
Route666
1,652
Brisbane, Australia
Jul 8, 2004
  • Jul 8, 2004
Ahhh cubic inches are volume not area. Did you mean sq inches?
1969mach1351
285
Sacramento, CA
Jul 8, 2004
  • Jul 8, 2004
oops Thanks for pointing that out Route666.
Route666
1,652
Brisbane, Australia
Jul 8, 2004
#10
  • Jul 8, 2004
  • #10
No wukkas!
TireSmoknWindsr
1,630
Half past whup'n some import's ass
Jul 8, 2004
#11
  • Jul 8, 2004
  • #11
After reading this thread....my head hurts
65straightsick
411
Montgomery, AL
Jul 8, 2004
#12
  • Jul 8, 2004
  • #12
Welcome back to school
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Cold Air Intake options, is this filter fine or......
  • from6to8
  • Aug 10, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Sep 7, 2024
from6to8
  • dan50
  • Jul 18, 2026
dan50
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
