does the aluminum drive shaft come with u joints?
I need to replace the u-joints on my car, eveytime i get on the gas or shift they clunk togather. Things start to go south in the drive line when you launch on sticky tires at 5000 rpm spraying a 125 shot.:p
What is the next weekest link after the drive shaft and u-joints?
Thanks guys.:Word:
a new FRPP DS does come with U joints. To do them on your old DS is not hard.
You really should want your clutch to be the weak link in the driveline. If it isnt, I hope you have a DS strap (check that - I hope you have one period).
Good luck
I'd suggest just replacing them on the stocker and get yourself a driveshaft loop....that is unless you have the cash to throw around for the aluminum shaft and the loop.
Or if using greasable joints, to index them so their structural integrity is not compromised as much.
Good luck.
