DOHC head options...
KurtPB
127
Lorimor, IA
well first question would have to be which volvo head do most 2.3t owners use when they do the swap and are they of the same years and if not, what years? also, would it be possible to just use a DOHC head off of a ford 2.3(even if it's n/a and although i assume it's the same as a volvo)?
No, its a Volvo 2.3 N/a head. Its not a direct swap and will require alot of modification to the head. Including, re-shaping the cylinder chambers, closing and re drilling water jackets, extending the head and re routing the oil returns. If that isnt enough, you will have to fab up a custom intake (or fork over the $$$ to buy one) and custom exhuast if you want a turbo setup on it. A pully/tensioner system will also have to be worked out. Good luck!
